跳转到主内容
AmazonBasics BTV1 Micro USB Jack Replacement
你所需要的
  1. AmazonBasics BTV1 Micro USB Jack Replacement, Battery: 步骤 1 中的图像 1,2 AmazonBasics BTV1 Micro USB Jack Replacement, Battery: 步骤 1 中的图像 2,2
    • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
    • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
  2. AmazonBasics BTV1 Micro USB Jack Replacement: 步骤 2 中的图像 1,2 AmazonBasics BTV1 Micro USB Jack Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
    • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
  3. AmazonBasics BTV1 Micro USB Jack Replacement: 步骤 3 中的图像 1,2 AmazonBasics BTV1 Micro USB Jack Replacement: 步骤 3 中的图像 2,2
    • Tilt the case downwards until the speakers fall out of their housings.
    • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
  4. AmazonBasics BTV1 Micro USB Jack Replacement: 步骤 4 中的图像 1,2 AmazonBasics BTV1 Micro USB Jack Replacement: 步骤 4 中的图像 2,2
    • Gently pull each plastic connector from the motherboard.
    • Take a note of which connector goes with each component for easy reassembly.
    • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
  5. AmazonBasics BTV1 Micro USB Jack Replacement: 步骤 5 中的图像 1,2 AmazonBasics BTV1 Micro USB Jack Replacement: 步骤 5 中的图像 2,2
    • Lift the motherboard off the face plate, exposing the battery.
    • Lift the battery out of its housing.
    • Use caution when using tools around the battery; batteries can be dangerous if punctured.
  6. AmazonBasics BTV1 Micro USB Jack Replacement, Micro USB Jack: 步骤 6 中的图像 1,3 AmazonBasics BTV1 Micro USB Jack Replacement, Micro USB Jack: 步骤 6 中的图像 2,3 AmazonBasics BTV1 Micro USB Jack Replacement, Micro USB Jack: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    • Using a Phillips #1 screwdriver, remove the two black 10mm screws on the interior of the case on the side with the USB and AUX inputs.
    • Use the plastic opening tool and tweezers at different points to work the audio input casing off.
  7. AmazonBasics BTV1 Micro USB Jack Replacement: 步骤 7 中的图像 1,2 AmazonBasics BTV1 Micro USB Jack Replacement: 步骤 7 中的图像 2,2
    • Use your fingers to pull casing off by the ribbon.
    • Use a Phillips #1 screwdriver to remove the two 7.6mm screws that hold the board in place.
  8. AmazonBasics BTV1 Micro USB Jack Replacement: 步骤 8 中的图像 1,2 AmazonBasics BTV1 Micro USB Jack Replacement: 步骤 8 中的图像 2,2
    • Use plastic opening tool to lift up the board.
    • Use plastic opening tool to gently push the aux input jack out of its housing.
  9. AmazonBasics BTV1 Micro USB Jack Replacement: 步骤 9 中的图像 1,1
    • Use the soldering iron to heat up solder joint and desoldering wick to remove the solder on each solder pad.
    • Do not apply heat from soldering iron for lengthy periods of time as this could potentially damage the board.
结论
2等其他人完成本指南。
Chris Shannon
于02/01/16注册
1,039 声望
创作了5篇指南
团队
USF Tampa, Team 14-2, Lacy Spring 2016 USF Tampa, Team 14-2, Lacy Spring 2016 的会员
USFT-LACY-S16S14G2
3 名成员
创作了5篇指南
1指南评论
that's awesome didn't i would find a tutorial but here it is. thanks man. What kind of usb connector do i use.
michael sorsby - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 726
