简介
The drive motor is what powers the shredding teeth via the drive gears. The motor may burn out due to age or extended use. It is found attached to the main shredder housing holding the shredding teeth and the drive gears.
你所需要的
Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
即将完成!
结论
另外一个人完成了本指南。
