简介
This repair would be necessary if the plastic drive gears within the AmazonBasics stripped, meaning the teeth were either ground down or broke off. A telltale sign of this is if you can hear the motor spinning, but the shredding blades do not move.
你所需要的
Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
即将完成!
结论
