简介
If the joystick thumbstick on your Amazon Luna Controller is worn out, unresponsive, or dirty, it can hinder your gaming experience and impact control precision. Replacing or cleaning the thumbstick is a simple process that requires minimal technical expertise. This guide will walk you through the steps to safely remove and replace the thumbstick, ensuring your controller performs optimally.
你所需要的
Flip the controller over to its front and locate the seam where the front plate connects to the rest of the body.
Remove the six 8 mm screws securing the controller's body using a TR9 Torx screwdriver.
Gently pull the joystick thumbstick straight up to remove it from the controller.
另外一个人完成了本指南。
