跳转到主内容
修复你的物品
维修的权力
商店
简介
As your Kindle gets older the battery life for it gets worse. This guide will teach you how to replace the battery for your Kindle, so you can enjoy hours of reading without having to charge it as often.
  1. Carefully wedge the plastic opening tool between the back panel and the device to free the clips holding the back panel and the device together.
    • Carefully wedge the plastic opening tool between the back panel and the device to free the clips holding the back panel and the device together.
  2. Work your way around the back panel to free all the clips. Work your way around the back panel to free all the clips. Work your way around the back panel to free all the clips.
    • Work your way around the back panel to free all the clips.
  3. Carefully remove the back panel from the device.
    • Carefully remove the back panel from the device.
    • Gently peel the back panel away from the adhesive, being mindful to keep the adhesive strip in good condition so that it can be used again.
    • Using tweezers, lift the orange bridge connector off.
    • Place the tweezers in between the battery and the end of the bridge and lift upwards.
    • Gently wedge the spudger under the battery starting from the left side, and slowly work the spudger around the edge to loosen the battery from the tape. Be careful not to rip the thin foil on the back of the battery.
    • Only use ESD safe tools when working on internal components of your device such as a spudger or opening tool.
    • It is not advised to use a metal spudger, as you could puncture the battery.
    • Lift the battery up using the spudger and use your fingers to slowly pull the battery off the adhesive.
    • Using the tweezers, gently lift the tape off of the Power bridge connector. If a new unit comes with a new piece of tape, remove entirely, if not remove and place one corner lightly face down on a clean surface to be used again.
  4. Once free of the adhesive and connectors, remove the old battery from the device.
    • Once free of the adhesive and connectors, remove the old battery from the device.
结论
7等其他人完成本指南。
Mohamed Elzini
于2017年09月27日注册
407 信誉积分
创作了4篇指南
团队
USF Tampa, Team S16-G5, Eyestone Fall 2017 USF Tampa, Team S16-G5, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S16G5
4 名成员
创作了10篇指南
Grate explanation. where can I find the battery? couldn’t find it anywhere
thanks
ALON GAZIT - 回复
Hi.. this is very helpful. But where does one buy a battery? Amazon doesn’t seem to sell them?
Ree - 回复
Hi, same comment: great and interesting but I can’t find the battery anywhere…
fabdelaere - 回复
WTH is a spudger?
Jim Price - 回复
You can find the battery here
https://www.nextbatteries.com/products/a...
890 mAH Li-Polymer 3.7V 61.60 x 53.32 x 2.78mm
Nat Whilk - 回复
添加评论
浏览统计数据:
过去的24小时: 25
过去的7天: 83
过去的30天: 390
总计 14,649
