本指南有最近更改,您可查看未经巡查的最新版本。
简介
As your Kindle gets older the battery life for it gets worse. This guide will teach you how to replace the battery for your Kindle, so you can enjoy hours of reading without having to charge it as often.
你所需要的
Carefully wedge the plastic opening tool between the back panel and the device to free the clips holding the back panel and the device together.
Using the tweezers, lift the orange bridge connector off.
Place the tweezers in between the battery and the end of the bridge and lift upwards.
18等其他人完成本指南。
23条评论
Grate explanation. where can I find the battery? couldn’t find it anywhere
thanks
ALON GAZIT - 回复
Hi, same comment: great and interesting but I can’t find the battery anywhere…
fabdelaere - 回复
You can find the battery here
https://www.nextbatteries.com/products/a...
890 mAH Li-Polymer 3.7V 61.60 x 53.32 x 2.78mm
