跳转到主内容
加入维修社区 - 创建账户
Amazon Kindle DX Battery Replacement
你所需要的
  1. Amazon Kindle DX Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the Kindle so the back is facing upwards.
  2. Amazon Kindle DX Battery Replacement: 步骤 2 中的图像 1,1
    • Push an opening tool against the bottom cover edge of the device. Move the tool's edge around the bottom plastic piece to pop it open.
  3. Amazon Kindle DX Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the plastic piece.
  4. Amazon Kindle DX Battery Replacement: 步骤 4 中的图像 1,2 Amazon Kindle DX Battery Replacement: 步骤 4 中的图像 2,2
    • Remove two 40 mm screws (one on each corner) using a Phillips #00 screwdriver.
  5. Amazon Kindle DX Battery Replacement: 步骤 5 中的图像 1,2 Amazon Kindle DX Battery Replacement: 步骤 5 中的图像 2,2
    • Use the edges of the opening tool, get in between the seams of the front and back panel, and use the tool to separate the pieces. Once loose, lift back panel off of the device.
  6. Amazon Kindle DX Battery Replacement: 步骤 6 中的图像 1,2 Amazon Kindle DX Battery Replacement: 步骤 6 中的图像 2,2
    • Remove two 30 mm screws securing the battery with a Phillips #00 screwdriver.
  7. Amazon Kindle DX Battery Replacement: 步骤 7 中的图像 1,2 Amazon Kindle DX Battery Replacement: 步骤 7 中的图像 2,2
    • Remove the battery from the device.
结论
13等其他人完成本指南。
Lori White
于09/28/16注册
577 声望
创作了3篇指南
团队
USF Tampa, Team 1-5, Cagle Fall 2016 USF Tampa, Team 1-5, Cagle Fall 2016 的会员
USFT-CAGLE-F16S1G5
3 名成员
创作了10篇指南
2指南评论
In Step 5, you actually can insert the tool into the 2 holes on side, slide along the edge to loose the back cover, then slide the cover down to remove it. No need to pry on the edge, which is quite difficult.
dracodoc - 回复
Thank you very much for a comprehensive guide. Especially the measurements for where to insert the screwdrivers were very helpful! Kind regards - Jakob
anonymous 5048 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 35
过去 30 天: 175
总计 12,964
