本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide takes you step by step through the process required to remove the buttons on the Amazon Fire remote. This task is simple and should not take more than a few minutes. To complete this you will need a plastic opening tool, triangle screwdriver, and a pair of precision tweezers. If you follow the easy steps you will successfully remove the buttons on the remote.
你所需要的
To remove the buttons use the blue plastic opening tool to pry out the outer ring.
3等其他人完成本指南。
3条评论
All the Amazon remote repair guides here need updating as many generations have come out since this original basic edition shown here. There are at least six other versions outside of this one. https://www.amazon.com/gp/help/customer/...
