跳转到主内容
Amazon Fire TV Stick Remote Button Panel Replacement
你所需要的
  1. Amazon Fire TV Stick Remote Button Panel Replacement, Remote Button Panel: 步骤 1 中的图像 1,3 Amazon Fire TV Stick Remote Button Panel Replacement, Remote Button Panel: 步骤 1 中的图像 2,3 Amazon Fire TV Stick Remote Button Panel Replacement, Remote Button Panel: 步骤 1 中的图像 3,3
    • To remove the buttons use the blue plastic opening tool to pry out the outer ring.
  2. Amazon Fire TV Stick Remote Button Panel Replacement: 步骤 2 中的图像 1,2 Amazon Fire TV Stick Remote Button Panel Replacement: 步骤 2 中的图像 2,2
    • Remove the inner disk.
    BEWARE! I took the circular button off because, after dropping the remote, the circle would not press down on the right side, however, all of the other functions (up, down, left and the center select button were working fine). After popping the circular button out and putting it back in, now none of the controls will press down. I'm sure it probably just needs to be aligned better but how exactly?
    Judith B - 回复
  3. Amazon Fire TV Stick Remote Button Panel Replacement: 步骤 3 中的图像 1,2 Amazon Fire TV Stick Remote Button Panel Replacement: 步骤 3 中的图像 2,2
    • Remove the 6mm triangle screw.
    Which screw driver you used for this, i looked at online and not sure size of screw.
    Akshay Rudraksha - 回复
    Mine does not have a screw under the button? So what now. It looks as if the remote has side clips that hold it togather?
    dbirdsell67 - 回复
  4. Amazon Fire TV Stick Remote Button Panel Replacement: 步骤 4 中的图像 1,2 Amazon Fire TV Stick Remote Button Panel Replacement: 步骤 4 中的图像 2,2
    • Remove top plate using plastic opening tools.
  5. Amazon Fire TV Stick Remote Button Panel Replacement: 步骤 5 中的图像 1,2 Amazon Fire TV Stick Remote Button Panel Replacement: 步骤 5 中的图像 2,2
    • Use tweezers to push out the buttons.
结论
3等其他人完成本指南。
Sami Uzzama
于07/12/16注册
615 声望
创作了2篇指南
团队
IUPUI, Team 2-3, Harley SU 2016 IUPUI, Team 2-3, Harley SU 2016 的会员
IUPUI-HARLEY-SU16S2G3
4 名成员
创作了13篇指南
3条评论
Where do you get the replacement parts
Chris S - 回复
You could probably find them on eBay.
[deleted] -
All the Amazon remote repair guides here need updating as many generations have come out since this original basic edition shown here. There are at least six other versions outside of this one. https://www.amazon.com/gp/help/customer/...
deilert - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 18
过去 30 天: 91
总计 22,930
