跳转到主内容
Amazon Fire TV Remote Control Motherboard Replacement
你所需要的
  1. Amazon Fire TV Remote Control Motherboard Replacement, Batteries: 步骤 1 中的图像 1,2 Amazon Fire TV Remote Control Motherboard Replacement, Batteries: 步骤 1 中的图像 2,2
    • Turn the remote control over to show its back and place your index finger in the tab. Squeeze gently to open the battery cover.
    • Lift the battery cover up to expose the batteries.
  2. Amazon Fire TV Remote Control Motherboard Replacement: 步骤 2 中的图像 1,2 Amazon Fire TV Remote Control Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use your index finger to push the battery back and lift up to remove the battery.
    • Repeat the procedure for the second battery.
  3. Amazon Fire TV Remote Control Motherboard Replacement, Remote Control Motherboard: 步骤 3 中的图像 1,2 Amazon Fire TV Remote Control Motherboard Replacement, Remote Control Motherboard: 步骤 3 中的图像 2,2
    • Locate the four 3.6 mm Phillips J#00 screws found under the back panel of the remote control and remove them.
  4. Amazon Fire TV Remote Control Motherboard Replacement: 步骤 4 中的图像 1,2 Amazon Fire TV Remote Control Motherboard Replacement: 步骤 4 中的图像 2,2
    • Locate the bottom of the remote control.
    • Place your thumb on the bottom part of the remote. Apply pressure as shown in the picture to release the back panel from the front of the case.
  5. Amazon Fire TV Remote Control Motherboard Replacement: 步骤 5 中的图像 1,2 Amazon Fire TV Remote Control Motherboard Replacement: 步骤 5 中的图像 2,2
    • Insert a plastic opening tool in the gap and apply some force to disconnect the two pieces away from each other.
    • Since there are two pins keeping the back of the case together with the motherboard, some force is needed to separate them.
  6. Amazon Fire TV Remote Control Motherboard Replacement: 步骤 6 中的图像 1,1
    • Unscrew the seven 2.4 mm Phillips J#00 screws that connect the motherboard to the case.
  7. Amazon Fire TV Remote Control Motherboard Replacement: 步骤 7 中的图像 1,1
    • Place the plastic opening tool or your fingernail in the gap at the top end and lift the motherboard.
结论
6等其他人完成本指南。
团队
USF Tampa, Team 16-3, Wollert Fall 2015 USF Tampa, Team 16-3, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G3
4 名成员
创作了16篇指南
3指南评论
Hello,
step 5 is wrong! There are no pins but screws!
You need to disconnect the upper piece (infrared sensor) first. Underneath you will find two more screws. Then you can open the case easily.
TheAffenkotze - 回复
The circuit board can not be fixed instead of replaced. Understand might be cheaper to replace
Seymour Butts - 回复
This was useful to me to find a location I could attach a lanyard to the remote. It is so small it keeps disappearing.
Patrick Kniesler - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 46
过去 30 天: 175
总计 15,632
