简介
This guide will walk you through the step-by-step procedures to remove and replace the speaker in your Amazon Fire TV Cube. These steps are simple, however some require considerable force. To complete this replacement you will need a small screwdriver and opening tool.
你所需要的
Using a metal spudger, push down between the edge seals on the base and pry off the base.
即将完成!
结论
2等其他人完成本指南。
