跳转到主内容
Amazon Fire TV Cube Speaker Replacement
你所需要的
  1. Amazon Fire TV Cube Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 Amazon Fire TV Cube Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 Amazon Fire TV Cube Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Using a metal spudger, push down between the edge seals on the base and pry off the base.
    • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
    • This may require substantial force.
  2. Amazon Fire TV Cube Speaker Replacement: 步骤 2 中的图像 1,3 Amazon Fire TV Cube Speaker Replacement: 步骤 2 中的图像 2,3 Amazon Fire TV Cube Speaker Replacement: 步骤 2 中的图像 3,3
    • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
    • There are 4 washers to go with each of the screws.
  3. Amazon Fire TV Cube Speaker Replacement: 步骤 3 中的图像 1,1
    • Lift and remove the full frame.
  4. Amazon Fire TV Cube Speaker Replacement: 步骤 4 中的图像 1,2 Amazon Fire TV Cube Speaker Replacement: 步骤 4 中的图像 2,2
    • Lift and remove the speaker.
    • Carefully match the outlets on the speaker with the outlets on the motherboard.
结论
2等其他人完成本指南。
一条评论
Our volume pauses every 11 minutes! Troubleshooting our Sono’s System…still doing it. Could this be our Fire Cube?
Lee - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 28
总计 3,290
