跳转到主内容
Amazon Fire TV Cube Motherboard Replacement
你所需要的
  1. Amazon Fire TV Cube Motherboard Replacement, Speaker: 步骤 1 中的图像 1,3 Amazon Fire TV Cube Motherboard Replacement, Speaker: 步骤 1 中的图像 2,3 Amazon Fire TV Cube Motherboard Replacement, Speaker: 步骤 1 中的图像 3,3
    • Using a metal spudger, push down between the edge seals on the base and pry off the base.
    • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
    • This may require substantial force.
  2. Amazon Fire TV Cube Motherboard Replacement: 步骤 2 中的图像 1,3 Amazon Fire TV Cube Motherboard Replacement: 步骤 2 中的图像 2,3 Amazon Fire TV Cube Motherboard Replacement: 步骤 2 中的图像 3,3
    • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
    • There are 4 washers to go with each of the screws.
  3. Amazon Fire TV Cube Motherboard Replacement: 步骤 3 中的图像 1,1
    • Lift and remove the full frame.
  4. Amazon Fire TV Cube Motherboard Replacement: 步骤 4 中的图像 1,2 Amazon Fire TV Cube Motherboard Replacement: 步骤 4 中的图像 2,2
    • Lift and remove the speaker.
    • Carefully match the outlets on the speaker with the outlets on the motherboard.
  5. Amazon Fire TV Cube Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,2 Amazon Fire TV Cube Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Lift the black latch by gently prying up with the flat end of the Spudger.
    • Detach the copper tap by pulling it out.
  6. Amazon Fire TV Cube Motherboard Replacement: 步骤 6 中的图像 1,2 Amazon Fire TV Cube Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use the pointed end of the Spudger to carefully detach the black and white wires from the motherboard.
    • Make sure all three attachments (the copper tab and both wires) are fully disconnected before continuing.
  7. Amazon Fire TV Cube Motherboard Replacement: 步骤 7 中的图像 1,2 Amazon Fire TV Cube Motherboard Replacement: 步骤 7 中的图像 2,2
    • Gently pry the motherboard up and off.
结论
3等其他人完成本指南。
2条评论
where do you buy the mother board ?
Sam Handa - 回复
This would be perfect if I could buy the dam motherboard. Where does one get because so far I’m not finding crap.
futuregu - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 23
总计 1,661
