跳转到主内容
加入维修社区 - 创建账户
Amazon Fire Phone Micro-USB Port Replacement
你所需要的
  1. Amazon Fire Phone Micro-USB Port Replacement, Tape the screen: 步骤 1 中的图像 1,1
    • If the display is damaged, use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: 步骤 2 中的图像 1,3 Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: 步骤 2 中的图像 2,3 Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: 步骤 2 中的图像 3,3
    • Power off your phone.
    • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Micro-USB Port Replacement: 步骤 3 中的图像 1,3 Amazon Fire Phone Micro-USB Port Replacement: 步骤 3 中的图像 2,3 Amazon Fire Phone Micro-USB Port Replacement: 步骤 3 中的图像 3,3
    • Press the small suction cup just above the home button.
    • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
  4. Amazon Fire Phone Micro-USB Port Replacement, Remove Bracket: 步骤 4 中的图像 1,1
    • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
    • Remove the silver bracket that was held into place by the three screws just removed.
  5. Amazon Fire Phone Micro-USB Port Replacement, Disconnect Battery: 步骤 5 中的图像 1,1
    • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
  6. Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: 步骤 6 中的图像 1,2 Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: 步骤 6 中的图像 2,2
    • Unscrew the 1mm screw on the top left side of the phone
    • Maneuver the bracket off slowly
  7. Amazon Fire Phone Micro-USB Port Replacement: 步骤 7 中的图像 1,3 Amazon Fire Phone Micro-USB Port Replacement: 步骤 7 中的图像 2,3 Amazon Fire Phone Micro-USB Port Replacement: 步骤 7 中的图像 3,3
    • Disconnect the 9 cables along the top and right side of motherboard using the plastic opening tool
  8. Amazon Fire Phone Micro-USB Port Replacement: 步骤 8 中的图像 1,1
    • Unscrew the 3mm screw located on the top left side of the phone with a flat head
  9. Amazon Fire Phone Micro-USB Port Replacement: 步骤 9 中的图像 1,3 Amazon Fire Phone Micro-USB Port Replacement: 步骤 9 中的图像 2,3 Amazon Fire Phone Micro-USB Port Replacement: 步骤 9 中的图像 3,3
    • Unscrew the four 2mm screws along the right side of the motherboard with a philips head
  10. Amazon Fire Phone Micro-USB Port Replacement: 步骤 10 中的图像 1,2 Amazon Fire Phone Micro-USB Port Replacement: 步骤 10 中的图像 2,2
    • Carefully lift up the motherboard and using the spudger pry camera from the camera holder
  11. Amazon Fire Phone Micro-USB Port Replacement: 步骤 11 中的图像 1,1
    • Lift off bottom plastic piece with flat antenna cables
结论
3等其他人完成本指南。
Kent Kawahara
于10/01/15注册
110 声望
撰写一个指南
团队
Cal Poly, Team 5-7, Maness Fall 2015 Cal Poly, Team 5-7, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G7
5 名成员
创作了10篇指南
2指南评论
one missing pic in step 9. also any ideas where i can get a replacement part?
Yu Ryu - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 36
总计 2,753
