跳转到主内容
Amazon Fire Phone Headphone Jack Replacement
你所需要的
  1. Amazon Fire Phone Headphone Jack Replacement, Front Panel Assembly: 步骤 1 中的图像 1,1
    • If the display is damaged use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: 步骤 2 中的图像 1,3 Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: 步骤 2 中的图像 2,3 Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: 步骤 2 中的图像 3,3
    • Power off your phone.
    • Remove the sim card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Headphone Jack Replacement, Manual Opening: 步骤 3 中的图像 1,3 Amazon Fire Phone Headphone Jack Replacement, Manual Opening: 步骤 3 中的图像 2,3 Amazon Fire Phone Headphone Jack Replacement, Manual Opening: 步骤 3 中的图像 3,3
    • Press the single suction cup just above the home button.
    • While lifting up on the suction cup place the plastic opening tool at the rim of the screen, separating the screen from the back casing.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone, freeing the two halves.
  4. Amazon Fire Phone Headphone Jack Replacement: 步骤 4 中的图像 1,3 Amazon Fire Phone Headphone Jack Replacement: 步骤 4 中的图像 2,3 Amazon Fire Phone Headphone Jack Replacement: 步骤 4 中的图像 3,3
    • Remove the 1mm screw concealed in the headphone jack.
    • Afterwards the headphone jack will easily pop off.
结论
2等其他人完成本指南。
Savannah Moen
于10/29/15注册
237 声望
撰写一个指南
团队
Cal Poly, Team 5-7, Maness Fall 2015 Cal Poly, Team 5-7, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G7
5 名成员
创作了10篇指南
一条评论
hello sir i need amazon fire back casing in Pakistan
Kashif Arif - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 1,870
