跳转到主内容
加入维修社区 - 创建账户
Amazon Fire Phone Display Replacement
你所需要的
    1. Amazon Fire Phone Display Replacement, Tape the screen: 步骤 1 中的图像 1,1
      • If the display is damaged, use clear packing tape to contain any glass shards.
      • Make sure the entire surface of the display is covered with tape.
      • Wear safety glasses to protect your eyes.
      询问修复机器人
      添加评论
    2. Amazon Fire Phone Display Replacement, Power off, remove SIM card, remove screws: 步骤 2 中的图像 1,3 Amazon Fire Phone Display Replacement, Power off, remove SIM card, remove screws: 步骤 2 中的图像 2,3 Amazon Fire Phone Display Replacement, Power off, remove SIM card, remove screws: 步骤 2 中的图像 3,3
      • Power off your phone.
      • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
      • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
      询问修复机器人
      添加评论
    3. Amazon Fire Phone Display Replacement: 步骤 3 中的图像 1,3 Amazon Fire Phone Display Replacement: 步骤 3 中的图像 2,3 Amazon Fire Phone Display Replacement: 步骤 3 中的图像 3,3
      • Press the small suction cup just above the home button.
      • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
      • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
      • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
      询问修复机器人
      添加评论
    4. Amazon Fire Phone Display Replacement, Remove Bracket: 步骤 4 中的图像 1,1
      • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
      • Remove the silver bracket that was held into place by the three screws just removed.
      添加评论
    5. Amazon Fire Phone Display Replacement, Disconnect Battery: 步骤 5 中的图像 1,1
      • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
      添加评论
    1. Amazon Fire Phone Display Replacement, Micro-USB Port: 步骤 6 中的图像 1,2 Amazon Fire Phone Display Replacement, Micro-USB Port: 步骤 6 中的图像 2,2
      • Unscrew the 1mm screw on the top left side of the phone
      • Maneuver the bracket off slowly
      询问修复机器人
      添加评论
    2. Amazon Fire Phone Display Replacement: 步骤 7 中的图像 1,3 Amazon Fire Phone Display Replacement: 步骤 7 中的图像 2,3 Amazon Fire Phone Display Replacement: 步骤 7 中的图像 3,3
      • Disconnect the 9 cables along the top and right side of motherboard using the plastic opening tool
      询问修复机器人
      添加评论
    3. Amazon Fire Phone Display Replacement: 步骤 8 中的图像 1,1
      • Unscrew the 3mm screw located on the top left side of the phone with a flat head
      询问修复机器人
      添加评论
    4. Amazon Fire Phone Display Replacement: 步骤 9 中的图像 1,3 Amazon Fire Phone Display Replacement: 步骤 9 中的图像 2,3 Amazon Fire Phone Display Replacement: 步骤 9 中的图像 3,3
      • Unscrew the four 2mm screws along the right side of the motherboard with a philips head
      询问修复机器人
      添加评论
    5. Amazon Fire Phone Display Replacement: 步骤 10 中的图像 1,2 Amazon Fire Phone Display Replacement: 步骤 10 中的图像 2,2
      • Carefully lift up the motherboard and using the spudger pry camera from the camera holder
      添加评论
    6. Amazon Fire Phone Display Replacement: 步骤 11 中的图像 1,1
      • Lift off bottom plastic piece with flat antenna cables
      添加评论
    1. Amazon Fire Phone Display Replacement, Display: 步骤 12 中的图像 1,1
      • We recommend you clean your microwave before preceding to heat up the iOpener.
      • Place the iOpener in the center of the microwave.
      • Heat the iOpener for thirty seconds.
      • Be careful not to overheat the iOpener and always wait at least three minutes before reheating the iOpener
      询问修复机器人
      添加评论
    2. Amazon Fire Phone Display Replacement: 步骤 13 中的图像 1,1
      • Lay the iOpener on side 1 of the phone for 90 seconds before attempting to open the front panel
      询问修复机器人
      添加评论
    3. Amazon Fire Phone Display Replacement: 步骤 14 中的图像 1,3 Amazon Fire Phone Display Replacement: 步骤 14 中的图像 2,3 Amazon Fire Phone Display Replacement: 步骤 14 中的图像 3,3
      • Using the Suction Cup to slightly lift the screen, pry one opening pick into side of the phone.
      • Insert another opening pick next to the first one.
      • Slowly slide the two Picks to the corners of the phone.
      询问修复机器人
      添加评论
    4. Amazon Fire Phone Display Replacement: 步骤 15 中的图像 1,3 Amazon Fire Phone Display Replacement: 步骤 15 中的图像 2,3 Amazon Fire Phone Display Replacement: 步骤 15 中的图像 3,3
      • Place the iOpener on side 2 of the phone for 90 seconds.
      • Insert another pick into side 2 of the phone.
      • Slowly slide the pick to the next corner.
      • If necessary, reheat the iOpener. Don't reheat it more than once every 3 minutes.
      询问修复机器人
      添加评论
    5. Amazon Fire Phone Display Replacement: 步骤 16 中的图像 1,3 Amazon Fire Phone Display Replacement: 步骤 16 中的图像 2,3 Amazon Fire Phone Display Replacement: 步骤 16 中的图像 3,3
      • Place the iOpener on the 3rd side of the phone for 90 seconds.
      • Place a pick in the corner of the phone.
      • Slowly slide the the pick to the opposite corner of the phone.
      询问修复机器人
      添加评论
    6. Amazon Fire Phone Display Replacement: 步骤 17 中的图像 1,3 Amazon Fire Phone Display Replacement: 步骤 17 中的图像 2,3 Amazon Fire Phone Display Replacement: 步骤 17 中的图像 3,3
      • Place the iOpener on the last edge of the phone for 90 seconds.
      • Place the pick in the corner.
      • Slowly slide the pick to the opposite corner.
      询问修复机器人
      添加评论
    7. Amazon Fire Phone Display Replacement: 步骤 18 中的图像 1,1
      • Carefully separate the screen from the front panel of the phone by inserting the picks farther towards the center and pulling the screen off.
      • Slowly and carefully do this to avoid breaking, bending or shattering the screen.
      • If part of the screen isn't easily coming off try reheating the iOpener and placing it on the problem area.
      询问修复机器人
      添加评论
    8. Amazon Fire Phone Display Replacement: 步骤 19 中的图像 1,1
      • Remove the screen slowly.
      • Pull the cable out of the hole carefully.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
团队
Cal Poly, Team 5-7, Maness Fall 2015 Cal Poly, Team 5-7, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G7
5 名成员
创作了60篇指南
1指南评论
how to replace touch?
coolsaad2010 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 62
总计 6,052
