简介
This will guide contains many steps so be patient and keep track of all parts removed. Using an iFixit Magnetic Project Mat is suggested.
你所需要的
Ensure that the device is turned off.
Holding the device firmly, wedge a plastic opening tool between the speaker cover and the device. Then pry up to separate it from the device.
Then begin to firmly pry up the plastic cover with the plastic opening tool.
Once you can fit your finger under the plastic cover, begin to slide your finger down the cover while simultaneously prying up.
Use a plastic opening tool to wedge between the screen and the device, while simultaneously holding the clip open from step 4.
Start to remove the screen from where the black plastic trim was removed and work the tool around the sides of the device. You will here small pops from the clips on the sides being released.
The Amazon Fire can now be opened with the two flex cables at the base still connected
Orient the device by rotating the body 90 degrees clockwise.
Peel off the black tape covering the main battery connection.
Now you will have to lift up the rear camera assembly that is covering the end of the copper strip.
Once you see the sharp corner of the copper strip, use a spudger to lift it off of the camera housing. Under the strip will be another connector cover in a small piece of black tape. Follow the steps from step 5 to remove the cable from this connection.
另外一个人完成了本指南。
