跳转到主内容
简介
In this guide, we will show you how to open the device and replace the screen. Before you start, make sure your device is powered off.
  1. Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away. Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device. Be mindful of the orange cable connecting the screen to the mid-bottom of the device. Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen. To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen. To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
结论
19等其他人完成本指南。
Dan Shimkus
于2016年02月24日注册
978 信誉积分
创作了3篇指南
团队
USF Tampa, Team 1-3, Leahy Spring 2016 USF Tampa, Team 1-3, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G3
4 名成员
创作了16篇指南
16条评论
Very nice, but even Amazon is not marketing the replacement screens.
Wendy Huntington Parker Fages - 回复
True, but if you happen to find another dysfunctional Fire ( with an intact screen) you can always harvest the display from that one and put it on your functioning unit. Long shot. But that's why this repair guide is still helpful even though parts aren't readily available.
Kelsea Weber -
Fingers crossed Amazon offers more parts in the future! :)
Kelsea Weber -
I ordered one from Amazon yesterday. Supposed to be 2 day shipping. Certainly not the $12 cheepy from China, but hopefully it will actually be shipped and delivered to my house. Any item Ive ever ordered that ended up being shipped directly from China has never found its way to my house and ends up costing about a months delay in the fixing of whatever device i have taken on the responsibility of to try & repair for someone.
Worth the $29 i’m paying at Amazon
Kitty Morgan -
添加评论
浏览统计数据:
过去的24小时: 7
过去的7天: 110
过去的30天: 553
总计 46,439
