跳转到主内容
Amazon Fire HD 8 Rear-facing Camera Replacement
你所需要的
  1. Amazon Fire HD 8 Rear-facing Camera Replacement, Screen: 步骤 1 中的图像 1,2 Amazon Fire HD 8 Rear-facing Camera Replacement, Screen: 步骤 1 中的图像 2,2
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Rear-facing Camera Replacement: 步骤 2 中的图像 1,1
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Rear-facing Camera Replacement: 步骤 3 中的图像 1,3 Amazon Fire HD 8 Rear-facing Camera Replacement: 步骤 3 中的图像 2,3 Amazon Fire HD 8 Rear-facing Camera Replacement: 步骤 3 中的图像 3,3
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Rear-facing Camera Replacement: 步骤 4 中的图像 1,3 Amazon Fire HD 8 Rear-facing Camera Replacement: 步骤 4 中的图像 2,3 Amazon Fire HD 8 Rear-facing Camera Replacement: 步骤 4 中的图像 3,3
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
  5. Amazon Fire HD 8 Rear-facing Camera Replacement, Rear-facing Camera: 步骤 5 中的图像 1,2 Amazon Fire HD 8 Rear-facing Camera Replacement, Rear-facing Camera: 步骤 5 中的图像 2,2
    • Pop the camera out of the rear-facing camera casing by carefully pulling the orange cable with the tweezers.
  6. Amazon Fire HD 8 Rear-facing Camera Replacement: 步骤 6 中的图像 1,2 Amazon Fire HD 8 Rear-facing Camera Replacement: 步骤 6 中的图像 2,2
    • Flip up the tab on the ZIF connector at the end of the ribbon cable.
    • Grasp the underside of the orange cable with the tweezers and gently slide the camera out of the connector.
结论
2等其他人完成本指南。
团队
USF Tampa, Team 1-3, Leahy Spring 2016 USF Tampa, Team 1-3, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G3
4 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,976
