跳转到主内容
简介
In this guide, we will show you how to replace the front camera. Before you start, make sure your device is powered off.
  1. Amazon Fire HD 8 Front Camera Replacement, Screen: 步骤 1 中的图像 1,2 Amazon Fire HD 8 Front Camera Replacement, Screen: 步骤 1 中的图像 2,2
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Front Camera Replacement: 步骤 2 中的图像 1,1
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Front Camera Replacement: 步骤 3 中的图像 1,3 Amazon Fire HD 8 Front Camera Replacement: 步骤 3 中的图像 2,3 Amazon Fire HD 8 Front Camera Replacement: 步骤 3 中的图像 3,3
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Front Camera Replacement: 步骤 4 中的图像 1,3 Amazon Fire HD 8 Front Camera Replacement: 步骤 4 中的图像 2,3 Amazon Fire HD 8 Front Camera Replacement: 步骤 4 中的图像 3,3
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
  5. Amazon Fire HD 8 Front Camera Replacement, Front Camera: 步骤 5 中的图像 1,3 Amazon Fire HD 8 Front Camera Replacement, Front Camera: 步骤 5 中的图像 2,3 Amazon Fire HD 8 Front Camera Replacement, Front Camera: 步骤 5 中的图像 3,3
    • Using a T4 screwdriver, remove the two screws situated on the left and right side of the camera.
    • The gasket may pop out, but it can easily be put back in.
  6. Amazon Fire HD 8 Front Camera Replacement: 步骤 6 中的图像 1,2 Amazon Fire HD 8 Front Camera Replacement: 步骤 6 中的图像 2,2
    • Using tweezers, gently remove the white tape with the QR code.
    • Fold the camera back and use tweezers to gently remove the orange tab.
结论
Dan Shimkus
于2016年02月24日注册
1,068 声望
创作了3篇指南
团队
USF Tampa, Team 1-3, Leahy Spring 2016 USF Tampa, Team 1-3, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G3
4 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 1,575
