简介
In this guide, we will show you how to replace the speaker on the bottom left of the device. Before you start, make sure your device is powered off.
你所需要的
Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
Using tweezers, carefully lift the copper strip from the right side of the speaker.
另外一个人完成了本指南。
一条评论
I would like to ask if you happen to know the part number of the speaker and where I could acquire said device?
Thank you a very helpful walk-through guide
