跳转到主内容
Amazon Fire HD 8 Bottom Speaker Replacement
你所需要的
  1. Amazon Fire HD 8 Bottom Speaker Replacement, Screen: 步骤 1 中的图像 1,2 Amazon Fire HD 8 Bottom Speaker Replacement, Screen: 步骤 1 中的图像 2,2
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Bottom Speaker Replacement: 步骤 2 中的图像 1,1
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Bottom Speaker Replacement: 步骤 3 中的图像 1,3 Amazon Fire HD 8 Bottom Speaker Replacement: 步骤 3 中的图像 2,3 Amazon Fire HD 8 Bottom Speaker Replacement: 步骤 3 中的图像 3,3
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Bottom Speaker Replacement: 步骤 4 中的图像 1,3 Amazon Fire HD 8 Bottom Speaker Replacement: 步骤 4 中的图像 2,3 Amazon Fire HD 8 Bottom Speaker Replacement: 步骤 4 中的图像 3,3
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
  5. Amazon Fire HD 8 Bottom Speaker Replacement, Bottom Speaker: 步骤 5 中的图像 1,1
    • Using tweezers, carefully lift the copper strip from the right side of the speaker.
  6. Amazon Fire HD 8 Bottom Speaker Replacement: 步骤 6 中的图像 1,2 Amazon Fire HD 8 Bottom Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove the two screws located on the top left and bottom right of the speaker using a T4 screwdriver.
  7. Amazon Fire HD 8 Bottom Speaker Replacement: 步骤 7 中的图像 1,1
    • Lift the right side of the speaker and carefully unhook and remove it from the device.
    • Be mindful of the white wire connecting the speaker to the device.
  8. Amazon Fire HD 8 Bottom Speaker Replacement: 步骤 8 中的图像 1,2 Amazon Fire HD 8 Bottom Speaker Replacement: 步骤 8 中的图像 2,2
    • Set aside the black speaker and follow the white wire to its connection on the upper left side of the motherboard.
    • Using tweezers, gently pry the black clip upward from the board.
结论
另外一个人完成了本指南。
Marisa Holste
于02/24/16注册
677 声望
撰写一个指南
团队
USF Tampa, Team 1-3, Leahy Spring 2016 USF Tampa, Team 1-3, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G3
4 名成员
创作了17篇指南
一条评论
I would like to ask if you happen to know the part number of the speaker and where I could acquire said device?
Thank you a very helpful walk-through guide
Keven Paxton - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 21
总计 4,132
