跳转到主内容
Amazon Fire HD 8 12th Gen Speakers Replacement
你所需要的
  1. 注意:步骤 1-2 源自标记为进行中的 指南
    Amazon Fire HD 8 12th Gen Speakers Replacement, Buttons: 步骤 1 中的图像 1,3 Amazon Fire HD 8 12th Gen Speakers Replacement, Buttons: 步骤 1 中的图像 2,3 Amazon Fire HD 8 12th Gen Speakers Replacement, Buttons: 步骤 1 中的图像 3,3
    • Remove the device from any electrical source and make sure it is powered off.
    • Put picks around the corner and move them along the edge to pry the case off.
    • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
  2. Amazon Fire HD 8 12th Gen Speakers Replacement: 步骤 2 中的图像 1,2 Amazon Fire HD 8 12th Gen Speakers Replacement: 步骤 2 中的图像 2,2
    • With the corners lifted, take the opening tool and pry each corner off.
    • Repeat this for the corner diagonal from the initial corner.
    • Once both corners are pried off, gently take the back case off the device.
  3. Amazon Fire HD 8 12th Gen Speakers Replacement, Speakers: 步骤 3 中的图像 1,1
    • Disconnect the red and black wires connected to the motherboard.
  4. Amazon Fire HD 8 12th Gen Speakers Replacement: 步骤 4 中的图像 1,3 Amazon Fire HD 8 12th Gen Speakers Replacement: 步骤 4 中的图像 2,3 Amazon Fire HD 8 12th Gen Speakers Replacement: 步骤 4 中的图像 3,3
    • Heat glue up to loosen the black and red wires, then lift and remove black and red wires.
    • Be careful of hot metals/parts and hot tools.
  5. Amazon Fire HD 8 12th Gen Speakers Replacement: 步骤 5 中的图像 1,3 Amazon Fire HD 8 12th Gen Speakers Replacement: 步骤 5 中的图像 2,3 Amazon Fire HD 8 12th Gen Speakers Replacement: 步骤 5 中的图像 3,3
    • Get metal speaker parts hot as well and lift the metal speaker up.
    • Do this for the other set of speakers and repeat the steps again.
    • Be careful of hot tools and hot parts.
结论
Jaden Palmer
于09/06/23注册
485 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 102
