跳转到主内容
Amazon Fire HD 7 (4th Generation) Battery Replacement
你所需要的
  1. Amazon Fire HD 7 (4th Generation) Battery Replacement, Battery: 步骤 1 中的图像 1,3 Amazon Fire HD 7 (4th Generation) Battery Replacement, Battery: 步骤 1 中的图像 2,3 Amazon Fire HD 7 (4th Generation) Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Insert the plastic opening tool behind the rear case to free the clips holding the case together.
    • Work your way around the device to free all the clips.
  2. Amazon Fire HD 7 (4th Generation) Battery Replacement: 步骤 2 中的图像 1,1
    • There are an additional 9 clips in the center of the case, surrounding the battery. Insert the plastic tool into the clips and lift to disconnect them.
    • Once all clips have been released, the back case can be pulled free to reveal the inside of the device.
  3. Amazon Fire HD 7 (4th Generation) Battery Replacement: 步骤 3 中的图像 1,2 Amazon Fire HD 7 (4th Generation) Battery Replacement: 步骤 3 中的图像 2,2
    • Insert the plastic tool below the battery connecting wires and lift the tool to disconnect the wires from the device.
  4. Amazon Fire HD 7 (4th Generation) Battery Replacement: 步骤 4 中的图像 1,3 Amazon Fire HD 7 (4th Generation) Battery Replacement: 步骤 4 中的图像 2,3 Amazon Fire HD 7 (4th Generation) Battery Replacement: 步骤 4 中的图像 3,3
    • Insert the tip of the plastic opening tool behind the sides of the battery.
    • Pry the battery apart to release it from the battery compartment.
    • Work along one side and repeat on the other.
  5. Amazon Fire HD 7 (4th Generation) Battery Replacement: 步骤 5 中的图像 1,1
    • Remove battery from compartment and replace it with a new one.
结论
13等其他人完成本指南。
Omir Rosado
于09/30/16注册
725 声望
创作了5篇指南
团队
USF Tampa, Team 4-4, Passmore Fall 2016 USF Tampa, Team 4-4, Passmore Fall 2016 的会员
USFT-PASSMORE-F16S4G4
4 名成员
创作了10篇指南
4条评论
Which direction are you placing the prying tool to release the clips; to open it up? With the prying tip facing up to release clips and then use to lift the back up as you move along the edges or face prying tip down to release clips which will then release the back to lift?
Also, using a black case, it’s hard to tell in the pic where exactly these clips are? Can you mark them on a photo?
Thank you! What seems to be an easy task is proving to be a struggle for my 4th Gen 7HD.
ugowhereigo - 回复
I have just replaced the battery in my wife's Kindle and the clips did not want to let go. I had to warn the back of the case with a hair dryer to get it to flex. The battery was well stuck down and needed a metal pry tool to release it.
Pedro Bedro - 回复
Replacing this battery looks very doable thanks to these instructions. But I was wondering what the risk is to damaging the LCD in the process? Thanks!
Cary Li - 回复
Thanks for the information, but is there any risk of electric shock?
Domenico Sacco - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 32
过去 30 天: 178
总计 21,096
