跳转到主内容
Amazon Fire HD 7 (4th Generation) Rear facing camera replacement
你所需要的
  1. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: 步骤 1 中的图像 1,3 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: 步骤 1 中的图像 2,3 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: 步骤 1 中的图像 3,3
    • Insert the plastic opening tool behind the rear case to free the clips holding the case together.
    • Work your way around the device to free all the clips.
  2. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: 步骤 2 中的图像 1,1
    • There are an additional nine clips surrounding the battery area. Place the plastic tool into the clips and lift to disconnect them.
    • Once all clips have been released, the back case can be pulled free to reveal the inside of the device.
  3. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: 步骤 3 中的图像 1,1
    • Use a nylon spudger to unclip the connection from the motherboard.
  4. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: 步骤 4 中的图像 1,2 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: 步骤 4 中的图像 2,2
    • Unscrew the two screws using a T5 screwdriver.
    • The camera lens are sensitive. Be careful when removing and handling camera.
    • Once freed from the screws, gently lift and remove the camera.
结论
Omir Rosado
于09/30/16注册
725 声望
创作了5篇指南
团队
USF Tampa, Team 4-4, Passmore Fall 2016 USF Tampa, Team 4-4, Passmore Fall 2016 的会员
USFT-PASSMORE-F16S4G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 16
总计 586
