跳转到主内容
加入维修社区 - 创建账户
Amazon Fire HD 3rd Gen Disassembly
你所需要的
  1. Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: 步骤 1 中的图像 1,3 Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: 步骤 1 中的图像 2,3 Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: 步骤 1 中的图像 3,3
    • Using a Jimmy, start at the volume control and work your way around by prying off the back and then lifting it back like a book.
  2. Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: 步骤 2 中的图像 1,3 Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: 步骤 2 中的图像 2,3 Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: 步骤 2 中的图像 3,3
    • Peel off the 2 yellow pieces of yellow tape on the battery.
  3. Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: 步骤 3 中的图像 1,3 Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: 步骤 3 中的图像 2,3 Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: 步骤 3 中的图像 3,3
    • Take off all the ribbon cables connected to the main board. (Marked in Red)
    • On the 2 speakers marked in yellow, be sure to pull straight up. Then unclip the speaker cables.
  4. Amazon Fire HD 3rd Gen Disassembly, Unscrew speakers and gray bracket: 步骤 4 中的图像 1,1
    • Using a T4 Torx driver, unscrew each of the 2 screws holding in the 2 speakers. (red)
    • Then, take out the 7 screws hold in the gray bracket (yellow)
    • Now, unscrew the 8 screws holding the motherboard. (green)
  5. Amazon Fire HD 3rd Gen Disassembly, Unscrew the I/O: 步骤 5 中的图像 1,1
    • Next, use a T4 Torx Screwdriver again to unscrew the headphone jack and the Micro USB port.
  6. Amazon Fire HD 3rd Gen Disassembly, Take everything out.: 步骤 6 中的图像 1,1
    • 1. Remove the Headphone and USB ports.
    • 2. Remove motherboard.
    • 3. Remove the speakers.
    • 4. Remove gray bracket with battery.
  7. Amazon Fire HD 3rd Gen Disassembly, Remove the screen.: 步骤 7 中的图像 1,1
    • Now, using a T4, unscrew the 4 screws holding in the screen.
  8. Amazon Fire HD 3rd Gen Disassembly, Your Done!: 步骤 8 中的图像 1,1
    • Congrats! Now follow the directions in reverse to reassemble your Fire!
终点
3等其他人完成本指南。
Cooper Anderson
于09/08/17注册
541 声望
创作了2篇指南
1指南评论
Please where can I get the digitizer?
Mine is shattered and I haven't used it for over 3years but I can still power it up.
Will very much appreciate a lead.
Patrick,
Nigeria
Patrick Mordi - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 2,004
