跳转到主内容
Amazon Fire HD 10 Screen Replacement
你所需要的
  1. Amazon Fire HD 10 Screen Replacement, Screen: 步骤 1 中的图像 1,3 Amazon Fire HD 10 Screen Replacement, Screen: 步骤 1 中的图像 2,3 Amazon Fire HD 10 Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Screen Replacement: 步骤 2 中的图像 1,1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Screen Replacement: 步骤 3 中的图像 1,2 Amazon Fire HD 10 Screen Replacement: 步骤 3 中的图像 2,2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the screen and digitizer from the case completely.
结论
26等其他人完成本指南。
Jaie Hillery
于10/07/14注册
1,718 声望
创作了10篇指南
团队
USF Tampa, Team 16-6, Blackwell Winter 2016 USF Tampa, Team 16-6, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S16G6
3 名成员
创作了22篇指南
16条评论
Where can you get a replacement digitizer screen? My grandson dropped his a couple days ago & I don't want to spend another $200 for a new one.
misterh - 回复
I am seeing replacement screen/digitizers for these now on ebay. With a little searching around I found one direct ship from Hong Kong for $70US. Good Luck!
Greg Charland -
I can't seem the find a replacement screen for this specification anywhere
Stephanie Eyime - 回复
I need the the cable that goes to the sceen. As i changed out my battery, when i tried to carefully remove the zif connector, it broke off. Woe is me.
boumpanimusic - 回复
What is needed to attach the screen back to the case?
Jimmy Lee - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 43
过去 30 天: 161
总计 34,874
