跳转到主内容
Amazon Fire HD 10 Rear Facing Camera Replacement
你所需要的
  1. Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: 步骤 1 中的图像 1,3 Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: 步骤 1 中的图像 2,3 Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: 步骤 1 中的图像 3,3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Rear Facing Camera Replacement: 步骤 2 中的图像 1,1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Rear Facing Camera Replacement: 步骤 3 中的图像 1,2 Amazon Fire HD 10 Rear Facing Camera Replacement: 步骤 3 中的图像 2,2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Rear Facing Camera Replacement: 步骤 4 中的图像 1,1
    • Remove the screen and digitizer from the case completely.
  5. Amazon Fire HD 10 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 5 中的图像 1,2 Amazon Fire HD 10 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 5 中的图像 2,2
    • Remove the single T5 Torx screw at the base of the camera.
    • Once removed, place the screw aside in a safe location.
  6. Amazon Fire HD 10 Rear Facing Camera Replacement: 步骤 6 中的图像 1,2 Amazon Fire HD 10 Rear Facing Camera Replacement: 步骤 6 中的图像 2,2
    • Lift the camera from the case using the plastic opening tool.
    • The camera is still connected to the motherboard via the ZIF connector.
  7. Amazon Fire HD 10 Rear Facing Camera Replacement: 步骤 7 中的图像 1,2 Amazon Fire HD 10 Rear Facing Camera Replacement: 步骤 7 中的图像 2,2
    • Gently grab the camera and pull to remove.
    • The camera is now free from the motherboard.
结论
2等其他人完成本指南。
Jaie Hillery
于10/07/14注册
1,718 声望
创作了10篇指南
团队
USF Tampa, Team 16-6, Blackwell Winter 2016 USF Tampa, Team 16-6, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S16G6
3 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 865
