跳转到主内容
Amazon Fire Game Controller Outer Shell Replacement
你所需要的
  1. Amazon Fire Game Controller Outer Shell Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Use a Triangle #2 screwdriver to remove the six 10 mm screws from the back of the controller.
  2. Amazon Fire Game Controller Outer Shell Replacement: 步骤 2 中的图像 1,1
    • Pry the two shell pieces from one another from the top orientation with a plastic opening tool.
    • The weights will fall out.
  3. Amazon Fire Game Controller Outer Shell Replacement: 步骤 3 中的图像 1,1
    • Disconnect the battery terminal wires and the play, pause, and stop wires from the motherboard.
  4. Amazon Fire Game Controller Outer Shell Replacement: 步骤 4 中的图像 1,1
    • Use a J1 screwdriver to unscrew the four 7 mm screws from the motherboard.
  5. Amazon Fire Game Controller Outer Shell Replacement: 步骤 5 中的图像 1,1
    • Lift the motherboard out of the controller casing.
  6. Amazon Fire Game Controller Outer Shell Replacement, Outer Shell: 步骤 6 中的图像 1,1
    • Use a JIS #0 screwdriver to remove the two 7 mm screws from the retaining bracket that secures the play, stop, and pause button wiring.
  7. Amazon Fire Game Controller Outer Shell Replacement: 步骤 7 中的图像 1,1
    • Use a JIS #0 screwdriver to unscrew the 5 mm screws from the LED indicator assembly.
  8. Amazon Fire Game Controller Outer Shell Replacement: 步骤 8 中的图像 1,2 Amazon Fire Game Controller Outer Shell Replacement: 步骤 8 中的图像 2,2
    • Slide out the triggers and bumpers.
结论
另外一个人完成了本指南。
团队
IUPUI, Team S4-G4, Wilson Summer 2019 IUPUI, Team S4-G4, Wilson Summer 2019 的会员
IUPUI-WILSON-SU19S4G4
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 735
