跳转到主内容
Amazon Echo Tweeter Replacement
你所需要的
  1. Amazon Echo Tweeter Replacement, Power and Speaker Driver Board: 步骤 1 中的图像 1,1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Tweeter Replacement: 步骤 2 中的图像 1,3 Amazon Echo Tweeter Replacement: 步骤 2 中的图像 2,3 Amazon Echo Tweeter Replacement: 步骤 2 中的图像 3,3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Tweeter Replacement: 步骤 3 中的图像 1,1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Tweeter Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Tweeter Replacement: 步骤 5 中的图像 1,2 Amazon Echo Tweeter Replacement: 步骤 5 中的图像 2,2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Tweeter Replacement: 步骤 6 中的图像 1,3 Amazon Echo Tweeter Replacement: 步骤 6 中的图像 2,3 Amazon Echo Tweeter Replacement: 步骤 6 中的图像 3,3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
  7. Amazon Echo Tweeter Replacement, Tweeter Assembly: 步骤 7 中的图像 1,2 Amazon Echo Tweeter Replacement, Tweeter Assembly: 步骤 7 中的图像 2,2
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo Tweeter Replacement: 步骤 8 中的图像 1,1
    • Peel off the black fabric wrapped around the Echo.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Tweeter Replacement: 步骤 9 中的图像 1,3 Amazon Echo Tweeter Replacement: 步骤 9 中的图像 2,3 Amazon Echo Tweeter Replacement: 步骤 9 中的图像 3,3
    • Remove the four 42.8 mm T10 Torx screws around the tweeter.
    • Lift the tweeter and its attached housing from the device.
  10. Amazon Echo Tweeter Replacement, Tweeter: 步骤 10 中的图像 1,2 Amazon Echo Tweeter Replacement, Tweeter: 步骤 10 中的图像 2,2
    • Using a spudger or your fingers, pull back the plastic clips near the edge of the tweeter.
    • Remove the tweeter from its plastic housing.
结论
另外一个人完成了本指南。
Alexander Albert
于02/04/16注册
1,145 声望
创作了6篇指南
团队
USF Tampa, Team 3-3, Wollert Spring 2016 USF Tampa, Team 3-3, Wollert Spring 2016 的会员
USFT-WOLLERT-S16S3G3
4 名成员
创作了12篇指南
3条评论
Anyone know where to get a replacement tweeter?
Ryan Alexander - 回复
Could you kindly post the dimension and depth of this tweeter/full range unit? Thank you.
No Body - 回复
Can anyone provide me the spare tweeter of Amazon echo dot 3rd generation
Pravesh Bansal - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 6,159
