简介
This guide demonstrates how to replace the tweeter assembly in the Amazon Echo. Removing the assembly is a prerequisite for replacing the tweeter or woofer.
你所需要的
Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
Könnt ihr Ersatzteil machen für Amazon Echo
Wo kann ich Ersatzteile holen für Amazon Echo
Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
Using the spudger, pull back the two plastic clips on the plate.
Lift the board up and pull it away from the plate.
I need to find a replacement board. Where can I find one?
Me to, i need this board to my alexa echo
Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
3条评论
Are you saying removing it and replacing the same tweeter is what you have to do? It says no parts.
The primary purpose of this guide is to show you how to remove a failing tweeter so that you can replace it with a new one. The "no parts required" text appears at the top of this guide because the author didn't have a source for the replacement part.
