跳转到主内容
加入维修社区 - 创建账户
Amazon Echo Tweeter Assembly Replacement
你所需要的
    1. Amazon Echo Tweeter Assembly Replacement, Power and Speaker Driver Board: 步骤 1 中的图像 1,1
      • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
      • Peel off the rubber footing from the bottom of the Echo.
      • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
      询问修复机器人
      添加评论
    2. Amazon Echo Tweeter Assembly Replacement: 步骤 2 中的图像 1,3 Amazon Echo Tweeter Assembly Replacement: 步骤 2 中的图像 2,3 Amazon Echo Tweeter Assembly Replacement: 步骤 2 中的图像 3,3
      • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
      询问修复机器人
      添加评论
    3. Amazon Echo Tweeter Assembly Replacement: 步骤 3 中的图像 1,1
      • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
      询问修复机器人
      添加评论
    4. Amazon Echo Tweeter Assembly Replacement: 步骤 4 中的图像 1,1
      在这个步骤中使用的工具:
      • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
      • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
      添加评论
    5. Amazon Echo Tweeter Assembly Replacement: 步骤 5 中的图像 1,2 Amazon Echo Tweeter Assembly Replacement: 步骤 5 中的图像 2,2
      • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
      • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
      添加评论
    6. Amazon Echo Tweeter Assembly Replacement: 步骤 6 中的图像 1,3 Amazon Echo Tweeter Assembly Replacement: 步骤 6 中的图像 2,3 Amazon Echo Tweeter Assembly Replacement: 步骤 6 中的图像 3,3
      • Using the spudger, pull back the two plastic clips on the plate.
      • Lift the board up and pull it away from the plate.
      添加评论
    1. Amazon Echo Tweeter Assembly Replacement, Tweeter Assembly: 步骤 7 中的图像 1,2 Amazon Echo Tweeter Assembly Replacement, Tweeter Assembly: 步骤 7 中的图像 2,2
      • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
      询问修复机器人
      添加评论
    2. Amazon Echo Tweeter Assembly Replacement: 步骤 8 中的图像 1,1
      • Peel off the black fabric wrapped around the Echo.
      • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
      询问修复机器人
      添加评论
    3. Amazon Echo Tweeter Assembly Replacement: 步骤 9 中的图像 1,3 Amazon Echo Tweeter Assembly Replacement: 步骤 9 中的图像 2,3 Amazon Echo Tweeter Assembly Replacement: 步骤 9 中的图像 3,3
      • Remove the four 42.8 mm T10 Torx screws around the tweeter.
      • Lift the tweeter and its attached housing from the device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
USF Tampa, Team 3-3, Wollert Spring 2016 USF Tampa, Team 3-3, Wollert Spring 2016 的会员
USFT-WOLLERT-S16S3G3
4 名成员
创作了25篇指南
3指南评论
I've gotten this far, but where do you get a replacement? No brand or model # on tweeter.
Kyle - 回复 分享
Are you saying removing it and replacing the same tweeter is what you have to do? It says no parts.
kathy1557 - 回复 分享
The primary purpose of this guide is to show you how to remove a failing tweeter so that you can replace it with a new one. The "no parts required" text appears at the top of this guide because the author didn't have a source for the replacement part.
Ron Davis - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 40
总计 4,412
