跳转到主内容
Amazon Echo Studio Power Supply Board Replacement
你所需要的
  1. Amazon Echo Studio Power Supply Board Replacement, Power Supply Board: 步骤 1 中的图像 1,3 Amazon Echo Studio Power Supply Board Replacement, Power Supply Board: 步骤 1 中的图像 2,3 Amazon Echo Studio Power Supply Board Replacement, Power Supply Board: 步骤 1 中的图像 3,3
    • Flip the device upside down.
    • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
  2. Amazon Echo Studio Power Supply Board Replacement: 步骤 2 中的图像 1,3 Amazon Echo Studio Power Supply Board Replacement: 步骤 2 中的图像 2,3 Amazon Echo Studio Power Supply Board Replacement: 步骤 2 中的图像 3,3
    • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
    • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
    • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
  3. Amazon Echo Studio Power Supply Board Replacement: 步骤 3 中的图像 1,3 Amazon Echo Studio Power Supply Board Replacement: 步骤 3 中的图像 2,3 Amazon Echo Studio Power Supply Board Replacement: 步骤 3 中的图像 3,3
    • Before fully removing the base, remove the three attached connectors.
  4. Amazon Echo Studio Power Supply Board Replacement: 步骤 4 中的图像 1,2 Amazon Echo Studio Power Supply Board Replacement: 步骤 4 中的图像 2,2
    • Now unscrew the the single 10 mm Phillips screw.
    • Remove the power supply board.
结论
2等其他人完成本指南。
Nick Saranich
于10/24/22注册
297 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-6, Petersen Fall 2022 UMass Dartmouth, Team 2-6, Petersen Fall 2022 的会员
UMASSD-PETERSEN-F22S2G6
4 名成员
创作了7篇指南
14指南评论
Thank you for this guide. It was very easy operation, but I believe problem with Echo is that its impossible to get spare parts?
My Echo Studio is in short circuit state.
https://ibb.co/kqTXw0w
https://ibb.co/zV4KH6y
https://ibb.co/GMgPDDY
https://ibb.co/4PMZjDj
https://ibb.co/k0MsFPM
Kertalaaki - 回复
Taking this thing apart really is easy. Thanks for the tip on how to get started. But as Kertalaaki figured, it seems there is no chance to get replacement parts. I guess Amazon prefers to sell new devices instead of having people repair their Studio device. I have a similar problem Kertalaaki describes. Whenever I plug the device in, it causes the breaker to blow. Now having the device in hand, I can't see any obvious damage as Kertalaakis photos show, but I still would like to get me a new power supply board. If anyone has any ideas on how to get one, please share! Thanks a lot in advance!
Ingo Gambin - 回复
Same Problem like Ingo and Kertalaaki. Did anyone figure out how to get a new power supply?
Martin Dirr - 回复
I contacted the Amazon regarding the matter, and spare parts are not available. The solution from their side was a credit towards a new device with a discount. Spare parts are not available.
Kertalaaki - 回复
The power source is custom built just for this implementation and there is nothing similar on the market as far I have found.
Kertalaaki - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 160
总计 2,374
