简介
If your Amazon Echo Show 5-megapixel camera is not functioning properly, you may need to replace it. Before starting this guide, gather a T-5 Torx screwdriver and iFixit opening tool. There are some steps where no tools are necessary and your hands can be used instead. Remember to be careful and gently remove items, such as the rubber foot.
你所需要的
在这个步骤中使用的工具:Tweezers$4.99
After the screws are removed, grip the front panel and separate the front from the back. This will expose the inside of the device.
Use tweezers or your hands to carefully disconnect the red wires connecting the speakers to the power supply board.
Lay the front section flat, with the screen down.
一条评论
Can not reset amazon echo show model MW46WB tried everything any suggestions
