跳转到主内容
Amazon Echo Show 5 Speaker Replacement
你所需要的
  1. Amazon Echo Show 5 Speaker Replacement, Amazon Echo Show 5 Disassembly: 步骤 1 中的图像 1,3 Amazon Echo Show 5 Speaker Replacement, Amazon Echo Show 5 Disassembly: 步骤 1 中的图像 2,3 Amazon Echo Show 5 Speaker Replacement, Amazon Echo Show 5 Disassembly: 步骤 1 中的图像 3,3
    • Power off and unplug the Amazon Echo Show 5. Failure to do so could result in injury or damage to the device.
    • Orient the Amazon Echo Show 5 so that the display is face down.
    • Use a spudger to remove the grey bottom cover.
    • During reassembly, adhesive needs to be applied to secure the bottom cover.
  2. Amazon Echo Show 5 Speaker Replacement: 步骤 2 中的图像 1,2 Amazon Echo Show 5 Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove the three screws with a T6 Torx screwdriver.
  3. Amazon Echo Show 5 Speaker Replacement: 步骤 3 中的图像 1,3 Amazon Echo Show 5 Speaker Replacement: 步骤 3 中的图像 2,3 Amazon Echo Show 5 Speaker Replacement: 步骤 3 中的图像 3,3
    • Use a spudger to release the six internal tabs lining the sides of the device.
    • There are fragile ribbon connectors along the side of the screen with the camera on it. So, do not stick the spudger more than a couple millimeters into the device.
  4. Amazon Echo Show 5 Speaker Replacement: 步骤 4 中的图像 1,1
    • Carefully open the device by folding it open along the top edge where the camera is located.
    • Do not try to open the device from any other side as this would damage the ribbon connectors.
  5. Amazon Echo Show 5 Speaker Replacement, Speaker: 步骤 5 中的图像 1,3 Amazon Echo Show 5 Speaker Replacement, Speaker: 步骤 5 中的图像 2,3 Amazon Echo Show 5 Speaker Replacement, Speaker: 步骤 5 中的图像 3,3
    • Carefully disconnect the red and black power connector.
  6. Amazon Echo Show 5 Speaker Replacement: 步骤 6 中的图像 1,3 Amazon Echo Show 5 Speaker Replacement: 步骤 6 中的图像 2,3 Amazon Echo Show 5 Speaker Replacement: 步骤 6 中的图像 3,3
    • Remove the three ZIF connector ribbon cables that connect the speaker housing to the display housing.
    • Do not pull ribbon cables straight out, as this will damage the device. To safely remove ribbon cables, pull up on the tab where the cable is going into.
  7. Amazon Echo Show 5 Speaker Replacement: 步骤 7 中的图像 1,3 Amazon Echo Show 5 Speaker Replacement: 步骤 7 中的图像 2,3 Amazon Echo Show 5 Speaker Replacement: 步骤 7 中的图像 3,3
    • Remove the four screws securing the speaker using a T6 Torx screwdriver.
  8. Amazon Echo Show 5 Speaker Replacement: 步骤 8 中的图像 1,3 Amazon Echo Show 5 Speaker Replacement: 步骤 8 中的图像 2,3 Amazon Echo Show 5 Speaker Replacement: 步骤 8 中的图像 3,3
    • Pull back the silver tape.
  9. Amazon Echo Show 5 Speaker Replacement: 步骤 9 中的图像 1,1
    • Carefully pull out the speaker housing from the black ledge.
结论
2等其他人完成本指南。
David Degbor
于10/26/22注册
277 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-4, Petersen Fall 2022 UMass Dartmouth, Team 2-4, Petersen Fall 2022 的会员
UMASSD-PETERSEN-F22S2G4
3 名成员
创作了7篇指南
3条评论
where can i locate a replacement loud speaker?
Mick Mul - 回复
Ive taken my speaker out and tested it, its fine
Its a software or dac chip issue.
Chris Foure -
Agreed , my speaker is muffled , ive just disassembled and want to test the speaker .
And... Yes ive reset thr device etc many times.
Chris Foure - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 59
总计 894
