跳转到主内容
Amazon Echo Show 2nd Gen Sound foam Replacement
你所需要的
  1. Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: 步骤 1 中的图像 1,3 Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: 步骤 1 中的图像 2,3 Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: 步骤 1 中的图像 3,3
    • Make sure the device is unplugged and powered off.
    • Turn the two screw plugs counterclockwise with a metal spudger until they are 90 degrees from their original position.
    • Pull each of the plugs out.
  2. Amazon Echo Show 2nd Gen Sound foam Replacement: 步骤 2 中的图像 1,3 Amazon Echo Show 2nd Gen Sound foam Replacement: 步骤 2 中的图像 2,3 Amazon Echo Show 2nd Gen Sound foam Replacement: 步骤 2 中的图像 3,3
    • Use the metal spudger to pry and create space between the sound foam and the frame.
    • Once you have sufficiently pried the foam from the frame on each side, detach the sound foam from the frame with your hands.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 1,592
