跳转到主内容
Amazon Echo Show 15 Motherboard Replacement
你所需要的
  1. Amazon Echo Show 15 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,3 Amazon Echo Show 15 Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,3 Amazon Echo Show 15 Motherboard Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Remove the four white stickers on your device's back panel.
    • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
    • A hair dryer may work best for this step.
  2. Amazon Echo Show 15 Motherboard Replacement: 步骤 2 中的图像 1,3 Amazon Echo Show 15 Motherboard Replacement: 步骤 2 中的图像 2,3 Amazon Echo Show 15 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
    • Pop the sides and remove the back panel of the device.
  3. Amazon Echo Show 15 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,3 Amazon Echo Show 15 Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,3 Amazon Echo Show 15 Motherboard Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Remove the five 3 mm screws from the metal protector using a Torx T5 screwdriver.
    • Take off the metal protector.
    • The metal protector is connected to the motherboard with adhesive. More force may be necessary.
    • Remove the twelve 3 mm screws from the motherboard using the Torx T5 screwdriver.
  4. Amazon Echo Show 15 Motherboard Replacement: 步骤 4 中的图像 1,3 Amazon Echo Show 15 Motherboard Replacement: 步骤 4 中的图像 2,3 Amazon Echo Show 15 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Detach the connectors for the camera and buttons from the motherboard.
    • Detach the connectors for the power station and speakers from the motherboard.
    • Detach the small white coaxial cables from the motherboard.
    • These connectors will be reused, so be very careful with them. The small white connectors come off by being pulled up.
  5. Amazon Echo Show 15 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the motherboard from the main device.
结论
Paysen Hudson
于09/20/23注册
181 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 35
总计 202
