跳转到主内容
加入维修社区 - 创建账户
Amazon Echo Show 15 Microphone Replacement
你所需要的
  1. Amazon Echo Show 15 Microphone Replacement, Back Panel: 步骤 1 中的图像 1,3 Amazon Echo Show 15 Microphone Replacement, Back Panel: 步骤 1 中的图像 2,3 Amazon Echo Show 15 Microphone Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Remove the four white stickers on your device's back panel.
    • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
    • A hair dryer may work best for this step.
    询问修复机器人
  2. Amazon Echo Show 15 Microphone Replacement: 步骤 2 中的图像 1,3 Amazon Echo Show 15 Microphone Replacement: 步骤 2 中的图像 2,3 Amazon Echo Show 15 Microphone Replacement: 步骤 2 中的图像 3,3
    • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
    • Pop the sides and remove the back panel of the device.
    询问修复机器人
  3. Amazon Echo Show 15 Microphone Replacement, Inner Black Panel: 步骤 3 中的图像 1,3 Amazon Echo Show 15 Microphone Replacement, Inner Black Panel: 步骤 3 中的图像 2,3 Amazon Echo Show 15 Microphone Replacement, Inner Black Panel: 步骤 3 中的图像 3,3
    • In the top right corner you will find a small black panel.
    • Remove the five 2 mm screws with a Torx T5 screwdriver.
    • Remove the two 5 mm with a Torx T3 screwdriver.
    • Remove both ends of the connector from the main device.
    • Remove the black panel.
  4. Amazon Echo Show 15 Microphone Replacement, Microphone: 步骤 4 中的图像 1,2 Amazon Echo Show 15 Microphone Replacement, Microphone: 步骤 4 中的图像 2,2
    • Locate the microphone panel on the top right hand corner.
    • Remove the two 3 mm screws with a Torx T3 screwdriver.
    询问修复机器人
  5. Amazon Echo Show 15 Microphone Replacement: 步骤 5 中的图像 1,2 Amazon Echo Show 15 Microphone Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the microphone.
    • You may use tweezers for this step if necessary.
    询问修复机器人
结论
Talara
于09/20/23注册
318 声望
创作了3篇指南
团队
2指南评论
Great tutorial. One question though, where do you get the new microphone?
Trevor Richardson - 回复 分享
Hi what is the other wire on the top that displays mic as well ?
Eddy Elias - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 57
总计 649
