跳转到主内容
Amazon Echo Power and Speaker Driver Board Replacement
你所需要的
  1. Amazon Echo Power and Speaker Driver Board Replacement, Power and Speaker Driver Board: 步骤 1 中的图像 1,1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Power and Speaker Driver Board Replacement: 步骤 2 中的图像 1,3 Amazon Echo Power and Speaker Driver Board Replacement: 步骤 2 中的图像 2,3 Amazon Echo Power and Speaker Driver Board Replacement: 步骤 2 中的图像 3,3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Power and Speaker Driver Board Replacement: 步骤 3 中的图像 1,1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Power and Speaker Driver Board Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Power and Speaker Driver Board Replacement: 步骤 5 中的图像 1,2 Amazon Echo Power and Speaker Driver Board Replacement: 步骤 5 中的图像 2,2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Power and Speaker Driver Board Replacement: 步骤 6 中的图像 1,3 Amazon Echo Power and Speaker Driver Board Replacement: 步骤 6 中的图像 2,3 Amazon Echo Power and Speaker Driver Board Replacement: 步骤 6 中的图像 3,3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
结论
10等其他人完成本指南。
Alexander Albert
于02/04/16注册
1,169 声望
创作了6篇指南
团队
USF Tampa, Team 3-3, Wollert Spring 2016 USF Tampa, Team 3-3, Wollert Spring 2016 的会员
USFT-WOLLERT-S16S3G3
4 名成员
创作了12篇指南
22指南评论
It's great that you have provided these instructions. I need to do this with mine. Do you know where I can get a replacement board?
Taylor Wolf - 回复
Taylor, did you ever find a new board? I need one too.
Mark Hall -
Great instructions BUT ...... THERE IS NO PLACE TO BUY THE BOARD!! (It's proprietary to Amazon) So this instruction is about as useful as jumping out of a plane before asking for a parachute.
blueskymining -
Where do I get a replacement board ?
Sean Burch - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 23
过去 30 天: 140
总计 28,408
