跳转到主内容
Amazon Echo Motherboard Replacement
你所需要的
  1. Amazon Echo Motherboard Replacement, Power and Speaker Driver Board: 步骤 1 中的图像 1,1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Motherboard Replacement: 步骤 2 中的图像 1,3 Amazon Echo Motherboard Replacement: 步骤 2 中的图像 2,3 Amazon Echo Motherboard Replacement: 步骤 2 中的图像 3,3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Motherboard Replacement: 步骤 3 中的图像 1,1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Motherboard Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Motherboard Replacement: 步骤 5 中的图像 1,2 Amazon Echo Motherboard Replacement: 步骤 5 中的图像 2,2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Motherboard Replacement: 步骤 6 中的图像 1,3 Amazon Echo Motherboard Replacement: 步骤 6 中的图像 2,3 Amazon Echo Motherboard Replacement: 步骤 6 中的图像 3,3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
  7. Amazon Echo Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,2 Amazon Echo Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo Motherboard Replacement: 步骤 8 中的图像 1,1
    • Peel off the black fabric wrapped around the device.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Motherboard Replacement: 步骤 9 中的图像 1,2 Amazon Echo Motherboard Replacement: 步骤 9 中的图像 2,2
    • Remove the four 9.7 mm T10 screws.
  10. Amazon Echo Motherboard Replacement: 步骤 10 中的图像 1,3 Amazon Echo Motherboard Replacement: 步骤 10 中的图像 2,3 Amazon Echo Motherboard Replacement: 步骤 10 中的图像 3,3
    • Lift the brown and black plastic latches securing the ZIF connectors at each end of the motherboard.
    • Pull the two ribbon cables from their connectors on the motherboard.
  11. Amazon Echo Motherboard Replacement: 步骤 11 中的图像 1,1
    • Lift the motherboard up from the Echo.
结论
5等其他人完成本指南。
Alexander Albert
于02/04/16注册
1,169 声望
创作了6篇指南
团队
USF Tampa, Team 3-3, Wollert Spring 2016 USF Tampa, Team 3-3, Wollert Spring 2016 的会员
USFT-WOLLERT-S16S3G3
4 名成员
创作了12篇指南
11指南评论
Where can you get the mmotherboard
Glen Seay - 回复
same question. where do i get replacement motherboard?
akn978s - 回复
This is how to remove the motherboard not how to replace it....geez
adairt - 回复
There is a reason why people look for information on how to remove it; and that is … TO REPLACE IT! So, where can you get a replacement?
arcsnsparks2000 - 回复
So no place to buy the motherboard, iv striped it down but can’t buy the board anywhere
mark crewe - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 76
总计 15,713
