简介
If your device is having trouble picking up your voice or doesn't recognize it at all, you may have a faulty microphone ribbon cable. This guide requires a plastic and metal spudger, and T4, T6, and T8 Torx screwdriver bits. The ribbon cable is relatively fragile, so be careful while removing it.
你所需要的
Using a spudger, remove the rubber footing around the base of the Echo Dot. This will reveal the four T8 1.25 cm Torx screws.
Now, use a plastic prying tool to remove the ribbon cable from the speaker housing.
即将完成!
结论
