跳转到主内容
Amazon Echo Dot 5th Generation Motherboard Replacement
你所需要的
  1. Amazon Echo Dot 5th Generation Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 Amazon Echo Dot 5th Generation Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Using a spudger, remove the rubber footing around the base of the Echo Dot. This will reveal the four T8 1.25 cm Torx screws.
  2. Amazon Echo Dot 5th Generation Motherboard Replacement: 步骤 2 中的图像 1,1
    • Once removed, the Echo Dot is now able to be split in two.
    • The ribbon cable connecting the microphone to the CPU PCB is now exposed, be careful not to tear it. The lower case will have the LED diffuser along the bottom, while the upper case will contain the rest of the internals.
  3. Amazon Echo Dot 5th Generation Motherboard Replacement: 步骤 3 中的图像 1,3 Amazon Echo Dot 5th Generation Motherboard Replacement: 步骤 3 中的图像 2,3 Amazon Echo Dot 5th Generation Motherboard Replacement: 步骤 3 中的图像 3,3
    • Remove the CPU PCB by removing the 4 T6 0.75cm Torx screws.
    • Once removed, unclip the plastic retainer on the CPU PCB and slide the ribbon cable out. This will reveal the speaker’s metal housing.
结论
Grace Warila
于10/30/23注册
206 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-4, Konn Fall 2023 UMass Dartmouth, Team 3-4, Konn Fall 2023 的会员
UMASSD-KONN-F23S3G4
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 43
总计 924
