跳转到主内容
Amazon Echo Dot 5th Generation Case Replacement
你所需要的
  1. Amazon Echo Dot 5th Generation Case Replacement, Motherboard: 步骤 1 中的图像 1,2 Amazon Echo Dot 5th Generation Case Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Using a spudger, remove the rubber footing around the base of the Echo Dot. This will reveal the four T8 1.25 cm Torx screws.
  2. Amazon Echo Dot 5th Generation Case Replacement: 步骤 2 中的图像 1,1
    • Once removed, the Echo Dot is now able to be split in two.
    • The ribbon cable connecting the microphone to the CPU PCB is now exposed, be careful not to tear it. The lower case will have the LED diffuser along the bottom, while the upper case will contain the rest of the internals.
  3. Amazon Echo Dot 5th Generation Case Replacement: 步骤 3 中的图像 1,3 Amazon Echo Dot 5th Generation Case Replacement: 步骤 3 中的图像 2,3 Amazon Echo Dot 5th Generation Case Replacement: 步骤 3 中的图像 3,3
    • Remove the CPU PCB by removing the 4 T6 0.75cm Torx screws.
    • Once removed, unclip the plastic retainer on the CPU PCB and slide the ribbon cable out. This will reveal the speaker’s metal housing.
  4. Amazon Echo Dot 5th Generation Case Replacement, Speaker: 步骤 4 中的图像 1,1
    • To access the speaker, take a plastic spudger and slowly lift the ribbon off of the housing.
    • Remove the four T8 1cm Torx screws around the edges of the metal housing.
    • Lift the top case off of the housing to reveal the speaker.
  5. Amazon Echo Dot 5th Generation Case Replacement: 步骤 5 中的图像 1,1
    • Using a Torx T5 bit, remove the four 1cm screws around the speaker and slide it out of the housing.
    • Pull 2 speaker cables off of the speaker and detach it.
  6. Amazon Echo Dot 5th Generation Case Replacement, Ribbon Cable: 步骤 6 中的图像 1,1
    • Now, use a plastic prying tool to remove the ribbon cable from the speaker housing.
  7. Amazon Echo Dot 5th Generation Case Replacement: 步骤 7 中的图像 1,1
    • Using the Torx T8 bit, remove the four 1.25 cm screws around the edges of the speaker housing, and lift the housing off of the top case, revealing the switch PCB.
  8. Amazon Echo Dot 5th Generation Case Replacement: 步骤 8 中的图像 1,3 Amazon Echo Dot 5th Generation Case Replacement: 步骤 8 中的图像 2,3 Amazon Echo Dot 5th Generation Case Replacement: 步骤 8 中的图像 3,3
    • Use a plastic spudger to undo the adhesive attaching the ribbon cable to the top case. Then, flip the tab on the switch PCB, and slide out the ribbon cable.
  9. Amazon Echo Dot 5th Generation Case Replacement, Switch PCB: 步骤 9 中的图像 1,3 Amazon Echo Dot 5th Generation Case Replacement, Switch PCB: 步骤 9 中的图像 2,3 Amazon Echo Dot 5th Generation Case Replacement, Switch PCB: 步骤 9 中的图像 3,3
    • Remove the upper switch PCB using the T4 Torx bit to unscrew the four 5 mm screws.
    • The PCB is glued down in between the 4 buttons.
    • Push down on the buttons through the top of the case and pry lightly with plastic tools until loose, then remove.
  10. Amazon Echo Dot 5th Generation Case Replacement, Case: 步骤 10 中的图像 1,1
    • By following the previous guides, the device should now be split in two, with the upper switch PCB removed from the top case.
    • Swap the old switch PCB into the new top case, and reassemble.
结论
Jack Salmonson
于10/30/23注册
190 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-4, Konn Fall 2023 UMass Dartmouth, Team 3-4, Konn Fall 2023 的会员
UMASSD-KONN-F23S3G4
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 17
过去 30 天: 57
总计 886
