跳转到主内容
Amazon Echo Dot 3rd Generation Speaker Replacement
你所需要的
  1. Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: 步骤 1 中的图像 1,3 Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: 步骤 1 中的图像 2,3 Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: 步骤 1 中的图像 3,3
    • Turn the Echo Dot over so the barcode is facing up, giving you access to the bottom of the device.
  2. Amazon Echo Dot 3rd Generation Speaker Replacement: 步骤 2 中的图像 1,2 Amazon Echo Dot 3rd Generation Speaker Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to gently lift the adhesive covering between the casing and the device.
  3. Amazon Echo Dot 3rd Generation Speaker Replacement: 步骤 3 中的图像 1,1
    • Use a T6 Torx screwdriver to remove the four 7.2 mm screws located around the corners of the device.
    • Make sure to keep the screws in a safe place for the reassembly process.
  4. Amazon Echo Dot 3rd Generation Speaker Replacement: 步骤 4 中的图像 1,2 Amazon Echo Dot 3rd Generation Speaker Replacement: 步骤 4 中的图像 2,2
    • Gently lift the casing of the device, starting from one side.
    • If the casing is stuck, use the spudger to carefully loosen it along the edges.
    • Be careful not to damage any internal components of the device.
  5. Amazon Echo Dot 3rd Generation Speaker Replacement, Speaker: 步骤 5 中的图像 1,1
    • Remove the four black 8.4 mm screws surrounding the speaker using a JIS #1 screwdriver.
  6. Amazon Echo Dot 3rd Generation Speaker Replacement: 步骤 6 中的图像 1,3 Amazon Echo Dot 3rd Generation Speaker Replacement: 步骤 6 中的图像 2,3 Amazon Echo Dot 3rd Generation Speaker Replacement: 步骤 6 中的图像 3,3
    • Use a spudger to pry the speaker out of the device.
结论
10等其他人完成本指南。
Elaina Moore
于09/15/22注册
187 声望
撰写一个指南
团队
14指南评论
Now where do I get the new speaker?
Philip Terry - 回复
Now WHERE do I get the new speaker?
vinodhkumar chejarla - 回复
WHERE DO WE GET THE REPLACEMENT speaker!?
Jerry Perry - 回复
I'm not sure if this is gonna work, but I have found a speaker on Amazon which is of the same size, almost the same wattage and same impedance. I'm only not sure about the depth of the speaker.
here is the link: https://amzn.in/d/5CvwhrW
I hope this helped!
Shri Mohan YV -
If you have a new one and the bass is a bit rattly just losten the speaker screws push lightly on the speaker whilst tightening the screws back up. It reduces the pressure and keeps the driver from hitting the case or moving to far out
GrantersG - 回复
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 117
过去 30 天: 437
总计 8,630
