跳转到主内容
Amazon Echo Dot 3rd Generation Motherboard Replacement
你所需要的
  1. Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: 步骤 1 中的图像 1,3 Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: 步骤 1 中的图像 2,3 Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: 步骤 1 中的图像 3,3
    • Turn the Echo Dot over so the barcode is facing up, giving you access to the bottom of the device.
  2. Amazon Echo Dot 3rd Generation Motherboard Replacement: 步骤 2 中的图像 1,2 Amazon Echo Dot 3rd Generation Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to gently lift the adhesive covering between the casing and the device.
  3. Amazon Echo Dot 3rd Generation Motherboard Replacement: 步骤 3 中的图像 1,1
    • Use a T6 Torx screwdriver to remove the four 7.2 mm screws located around the corners of the device.
    • Make sure to keep the screws in a safe place for the reassembly process.
  4. Amazon Echo Dot 3rd Generation Motherboard Replacement: 步骤 4 中的图像 1,2 Amazon Echo Dot 3rd Generation Motherboard Replacement: 步骤 4 中的图像 2,2
    • Gently lift the casing of the device, starting from one side.
    • If the casing is stuck, use the spudger to carefully loosen it along the edges.
    • Be careful not to damage any internal components of the device.
  5. Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,3 Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,3 Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: 步骤 5 中的图像 3,3
    • Remove the four 6.2 mm screws from the motherboard using a T6 Torx screwdriver.
    • Remove the three 9.4 mm screws from the motherboard using a T6 Torx screwdriver.
  6. Amazon Echo Dot 3rd Generation Motherboard Replacement: 步骤 6 中的图像 1,3 Amazon Echo Dot 3rd Generation Motherboard Replacement: 步骤 6 中的图像 2,3 Amazon Echo Dot 3rd Generation Motherboard Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove the connecting head linking the motherboard to the device using a pair of tweezers.
    • Remove the old motherboard and replace it with the new one.
结论
2等其他人完成本指南。
3指南评论
Where do we get the parts you bi chh
Fcukermother - 回复
Amazon does not sell any parts for the Echo devices. Your best and probably only alternative is to buy a used Echo from eBay and use this guide to repair it.
raymondjram -
Can you get or buy replament mother boards for the ehco 5 ?
Shawn Haywood - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 32
过去 30 天: 152
总计 2,898
