简介
If your Amazon Echo Dot 3rd Generation is experiencing hardware issues, but the app is still functioning, your motherboard may need to be replaced. Follow this guide to do so.
The motherboard, or main board, of the Echo Dot is the control center from which your device takes all its commands. If your main board is not functioning properly, it will need to be replaced.
Before replacing the main board, check your device for other causes of disruption. For example, if you find that Alexa is not responding to you, but the lights are functioning, you may be experiencing a speaker issue.
Before attempting, make sure the Echo Dot is turned off and unplugged from the external power source.
你所需要的
Turn the Echo Dot over so the barcode is facing up, giving you access to the bottom of the device.
Remove the four 6.2 mm screws from the motherboard using a T6 Torx screwdriver.
Remove the three 9.4 mm screws from the motherboard using a T6 Torx screwdriver.
2等其他人完成本指南。
3指南评论
Where do we get the parts you bi chh
Amazon does not sell any parts for the Echo devices. Your best and probably only alternative is to buy a used Echo from eBay and use this guide to repair it.
Can you get or buy replament mother boards for the ehco 5 ?
