跳转到主内容
Amazon Echo Dot 3rd Generation Casing Replacement
你所需要的
  1. Amazon Echo Dot 3rd Generation Casing Replacement, Casing: 步骤 1 中的图像 1,3 Amazon Echo Dot 3rd Generation Casing Replacement, Casing: 步骤 1 中的图像 2,3 Amazon Echo Dot 3rd Generation Casing Replacement, Casing: 步骤 1 中的图像 3,3
    • Turn the Echo Dot over so the barcode is facing up, giving you access to the bottom of the device.
  2. Amazon Echo Dot 3rd Generation Casing Replacement: 步骤 2 中的图像 1,2 Amazon Echo Dot 3rd Generation Casing Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to gently lift the adhesive covering between the casing and the device.
  3. Amazon Echo Dot 3rd Generation Casing Replacement: 步骤 3 中的图像 1,1
    • Use a T6 Torx screwdriver to remove the four 7.2 mm screws located around the corners of the device.
    • Make sure to keep the screws in a safe place for the reassembly process.
  4. Amazon Echo Dot 3rd Generation Casing Replacement: 步骤 4 中的图像 1,2 Amazon Echo Dot 3rd Generation Casing Replacement: 步骤 4 中的图像 2,2
    • Gently lift the casing of the device, starting from one side.
    • If the casing is stuck, use the spudger to carefully loosen it along the edges.
    • Be careful not to damage any internal components of the device.
结论
To reassemble your Echo Dot, follow these instructions in reverse order. Ensure the casing fits properly before tightening the screws back on. Once reassembly is finished, check that the device powers on and functions correctly.
2等其他人完成本指南。
Kristen Gismondi
于11/12/14注册
100,426 声望
创作了258篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,784篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 44
总计 1,160
