跳转到主内容
Amazon Echo Dot 3rd Gen Disassembly
你所需要的
  1. Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: 步骤 1 中的图像 1,3 Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: 步骤 1 中的图像 2,3 Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: 步骤 1 中的图像 3,3
    • When Prying the bottom off, insert the Metal Spudger under the bottom where the ports are
    • Avoid letting the Adhesive touch anything, lay the plate on the branded side
    • If the adhesive is to strong use a hair dryer to soften it
  2. Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: 步骤 2 中的图像 1,3 Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: 步骤 2 中的图像 2,3 Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: 步骤 2 中的图像 3,3
    • Use a TORX T6H bit to remove the four screws on the bottom
    • When all the screws are taken out lift up and the covering should slide off
  3. Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: 步骤 3 中的图像 1,3 Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: 步骤 3 中的图像 2,3 Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: 步骤 3 中的图像 3,3
    • Remember to un latch the ribbon cable before pulling the circuit board up
  4. Amazon Echo Dot 3rd Gen Disassembly, Removing the top: 步骤 4 中的图像 1,3 Amazon Echo Dot 3rd Gen Disassembly, Removing the top: 步骤 4 中的图像 2,3 Amazon Echo Dot 3rd Gen Disassembly, Removing the top: 步骤 4 中的图像 3,3
    • To get the further screws on the bottom, use a 4 mm nut driver and put the TORX bit in the nut driver as an extension
    • Pull up on the metal to release the top from the rest
  5. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: 步骤 5 中的图像 1,3 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: 步骤 5 中的图像 2,3 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: 步骤 5 中的图像 3,3
    • Undo the four screws the remove the white defuser piece (I lost a screw)
  6. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top even further: 步骤 6 中的图像 1,2 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top even further: 步骤 6 中的图像 2,2
    • The two should separate if you hold the edge, if it doesn't push a button on top and it should pop out
结论
7等其他人完成本指南。
Ben Nicholsonb
于07/09/21注册
349 声望
撰写一个指南
3指南评论
Parabéns pelo tutoria de desmontagem do aparelho ALEXA ECHO DOT 3ª geração! Excelente trabalho!!!
Eu recebi um aparelho desse para efetuar a manutenção, pois este estavatotalmente inoperante, por dois motivos:
1° ADAPTADOR FONTE AVARIADO, gerando tensão de saída DC oscilante;
2° MAL-CONTATO NO CABO FLEXÍVEL INTERNO que conecta as duas placas eletrônicas internas.
eduardosanchessales - 回复
How can I convert Amazon Echo Dot power from AC to DC?
Gift Sikufele - 回复
ciao, per caso sai indicarmi la parte specializzata per la rete wi-fi o segnali, ho un eco dot uguale e non viene rilevato in nessun modo per questo volevo vedere se ci fosse qualche problema al ricevitore wifi
Matteo Sala - 回复
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 110
过去 30 天: 456
总计 15,765
