跳转到主内容
Amazon Echo Dot 2nd Generation Speaker Replacement
你所需要的
  1. Amazon Echo Dot 2nd Generation Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 Amazon Echo Dot 2nd Generation Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 Amazon Echo Dot 2nd Generation Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation Speaker Replacement: 步骤 2 中的图像 1,3 Amazon Echo Dot 2nd Generation Speaker Replacement: 步骤 2 中的图像 2,3 Amazon Echo Dot 2nd Generation Speaker Replacement: 步骤 2 中的图像 3,3
    • Use the T8 screwdriver bit to unscrew the four 1.6mm torx screws
    • Remove the black, cylindrical base
  3. Amazon Echo Dot 2nd Generation Speaker Replacement: 步骤 3 中的图像 1,1
    • Tap the base against the palm of your hand so that the black speaker component comes out
结论
14等其他人完成本指南。
Alexis White
于10/09/17注册
505 声望
创作了2篇指南
团队
USF Tampa, Team S1-G3, Leahy Fall 2017 USF Tampa, Team S1-G3, Leahy Fall 2017 的会员
USFT-LEAHY-F17S1G3
3 名成员
创作了12篇指南
3条评论
Where can one purchase the replacement speaker component?
ananomaus - 回复
Can you inform us were to get replacement speaker please.
John Stead - 回复
Yeah where can we buy the speaker? This tutorial doesn’t show how to replace it, it shows where to find it
Meghan Craig - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 77
总计 13,176
