简介
Use this guide to replace the ribbon cable in the Amazon Echo Dot 2nd Generation.
你所需要的
Power off and unplug the echo
Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
Use the metal spudger to lift the ZIF connector
Remove the ribbon cable from the slot on the LED/speaker board
Hi where can I buy a replacement ribbon? Mine split when the speaker fell. :( Thank you for your help.
4等其他人完成本指南。
5条评论
Where do you get the replacement cable from?
Yes, where can one get replacement ribbon cables?
I need a replacement as well now was using a pointed tweezers when putting it back together and stabbed the cable need to find part and order from the uk
no cable available, just waiting for donors
